memory
memory
Message 1 of 10
memory
autocad LT 2016
how much disk space does the progam take up, and how much extra disk space is needed for operating?
Revit 2016
Replies (9)
Message 2 of 10
pendean
Community Legend
Community Legend
If you have to ask, does that mean your C: drive is so small you are worried about it?
AutoCAD/LT is a 1.2Gig download that expands into a 2.5Gig installer that needs 2.5Gig space to install and claen up. REVIT double or triples that.
Message 3 of 10
Thanks Dean.
Yup, i am out of memory. Running Acad 2015 LT on imac with boot camp and windows 7 pro. dpartition has 55.8 GB, with only 978 MB free.
Thinking about re-partitioning the drive to gain space. wondering how many GB to add to make 2015 LT run well again? working SF Residential and single story commercial and industrial projects.
also considering adding Revit LT for similiar projects.
Message 4 of 10
pendean
Community Legend
Community Legend
10Gig free minimum.
Message 5 of 10
I'll need to purchase new Windows. Will Windows 8 be a good choice? acadmca
Message 6 of 10
pendean
Community Legend
Community Legend
New PC?
Message 7 of 10
no. it is my imac with boot camp. currently use windows 7.1. was concerned that autocad and revit are not yet good on windows 10.  thanks!
Message 8 of 10
stevetamplen
Hello acadmca, and welcome to the Forums!
Here is a link to the Autodesk resource for System Requirements:
System requirements for AutoCAD
From there, you can check the system requirements for any version of AutoCAD. These will include OS, memory and disk space requirements.
As far as Windows 10 and AutoCAD, I would try to avoid that for a while while the problems get worked out, if you can.
Also, please try to use the correct terminology so other posters know what you are saying: "Yup, I am out of memory" should be "I am out of hard drive space" as memory typically refers to system memory, or RAM.
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Steve Tamplen
Technical Support Specialist
Message 9 of 10
WARNING: These are my personal opinions as a former system builder/gamer/drafter.
You should consider the following carefully when looking at upgrade options.
1. If your system still has room for more RAM, you should consider maxing it out if that is in your budget. Try to match the RAM (so all the sticks are the same), as that helps with system stability.
If you are running VMs and Autocad, every little bit will help.
2. When you upgrade your hard drive, if you can use a Solid State Drive (SSD) you should consider doing so, they are a lot faster and, of course, more expensive, as they are essentially just a bunch of RAM.
Many users have a SSD as their boot drive to improve performance, and a standard large Hard Disk Drive (HDD) to hold a bunch of data, but again, that is a more expensive option.
If you cannot use (or afford) a SSD, look at the largest (affordable) drive that is compatible with your system, and choose the highest spindle speed/largest cache as those will help improve performance.
3. If you are buying online, make sure you choose a reputable vendor like Newegg that has a great reputation and a good return policy (just in case).
Message 10 of 10
stevetamplen
@Anonymous
Have you gotten enough information, or do you still need more help?
Please post back to let me know, and I will be happy to continue assisting you!
Did any of the posts get your problem resolved?
If so, please hit the Accept as Solution button for the appropriate post so that more community members can profit from the solution.
Steve Tamplen
