Many Dynamic Blocks - Slow Regens, Big File - Alternatives?
Robert.FordEH6ZF
Message 1 of 19
Robert.FordEH6ZF
I'm working on a warehouse layout, and I'm using dynamic blocks for racks and floor storage locations. These allow me to use a few blocks to represent multiple sizes and orientations and also to allow for data extraction (e.g., location name, x and y coordinates, etc.). However, my drawing has over 7,000 instances of a block. Obviously, regens and file saves take a looooong time (several minutes each).
Is there a better way to do this?
The greatest single benefit for me is that I can use the drawing to export the x and y coordinates of each block, import them into Excel, and, combining them with WMS transaction data, calculate and optimize travel distances in the warehouse.
Replies (18)
Message 2 of 19
pendean
Community Legend
Community Legend
7,000 multiplied by the variations available and it can get quite the tracking task for the program: what year version are you running, PC specs and which OS?
Message 3 of 19
Robert.FordEH6ZF
HP ZBook
Windows 10 64-bit
AutoCAD LT 2021
16GB RAM
i7-8750H 2.20GHz
Nvidia Quadro P1000
Message 4 of 19
steven-g
Just plain old blocks may be better if there are not too many variations. A single simple block repeated 1000 times is no problem for Autocad, but a dynamic block with exactly the same settings in each one repeated 1000 times is a different storey, Each one becomes an anonymous block and Autocad has to keep track of the settings for each block as well as the block description.
In small doses, dynamic blocks can be great but it's a different storey for large numbers.
Message 5 of 19
Robert.FordEH6ZF
There are 6 or so variations of the block--different sizes. However, I'd like to identify each location with an attribute, whether nested within the block or as a separate entity. I need to be able to extract the x and y coordinates with unique, logical identifiers (e.g., A0101 = zone A, aisle 1, bay 1).
Message 6 of 19
steven-g
Just a plain old block can contain attributes no need to be dynamic for that. Dynamic blocks do carry a lot of overhead.
Message 7 of 19
Robert.FordEH6ZF
So, I can have multiple (hundreds, thousands) instances of the same non-dynamic block, but each instance can have a unique attribute associated with it?
Message 8 of 19
pendean
Community Legend
Community Legend
Each can have a unique attribute value assigned to it, yes.
Message 9 of 19
steven-g
And using multiple attributes for zone, aisle, and bay you can select multiple blocks (say all in one aisle) and change the attributes for all of them in the properties palette at the same time.
Message 10 of 19
Robert.FordEH6ZF
That's exactly what I was doing with the dynamic blocks! The downside is that I lose the flexibility of dynamic blocks (i.e., one block that can handle different sizes), but having the improved performance with non-dynamic blocks should be worth it. Either I had forgotten or I didn't realize that you can have "dynamic" attributes with "static" blocks. Thank you for your help.
Message 11 of 19
Robert.FordEH6ZF
Examples of the benefit of dynamic blocks:
Our pallet racks can have 11 possible lengths, 6 depths, and 2 types of uprights...132 potential static blocks vs 1 dynamic block. (Fortunately, we don't use all possible combinations.)
And, I can't rotate labels so they're not upside down.
Message 12 of 19
pendean
Community Legend
Community Legend
No one is anti-dynblocks here: your issue is and remains AutoCAD/Lt cannot handle too many of them in a file.
So either live with the challenges you are facing with performance on your laptop (you should see less of it on a better spec'd desktop but it will still be there) or just be way more deliberate about where to use dynblocks (critical always-changing locations vs. 7000 copies that once placed with never change).
Your tough choice: an ours, and everyone using autoCAD.
HTH
Message 13 of 19
Robert.FordEH6ZF
That was just me venting. I'm surprised at how much overhead they consume.
Message 14 of 19
tracey.platt
Hi, did you ever sort your dynamic block issues with regards to speed and regen etc in your drawings? I have a similar issue where i have created one dynamic block for example a 45 deg bend which in the past has had hundred of size and material variations and created one dynamic block which i use to extract all my stock codes, etc and other things but it is really slowing down my drawing and take few minutes to insert . I have not been able to find any info online but came across your post whilst doing a search.
Message 15 of 19
steven-g
Nothing has changed, large numbers of dynamic blocks will just slow a drawing down.
Message 16 of 19
pendean
Community Legend
Community Legend
There is no fix from Autodesk at this time. Join everyone and ask Autodesk for it here https://www.autodesk.com/company/contact-us/product-feedback
Message 17 of 19
krazeymike
I may have a solution for you as I had a similar issue with thousands of Dynamic Blocks in some drawings.
Firstly simplify the block by purging anything in the block not being used.
Secondly under Options - System - Layout Regen Options, Check the box that says "Cache model tab and all layouts" then Restart Acad.
This made all the issues I had with slow drawings go away since it is only an issue whenever AutoCAD has to Regen the dynamic block properties every time you switch layouts.
When you open a Layout for the first time it may be slow but afterwards every time you swap between them it should be back to normal
Message 18 of 19
h_s_walker
I'm not sure if it is on now, but that was never an option for LT and it wasn't at least up until LT2016, but it is still a good tip.
Howard Walker
Left Handed and Proud
Message 19 of 19
RobFord2112
Community Visitor
Community Visitor
I know it’s been almost a year, but I just now saw your reply. I’ll give “cache” setting a try. Thanks!
