08:51 AM
My AutoCAD has started to draw dimensions with the start and end points of the dim offset away from the selected points on objects. It only does this when snapping to objects is selected. It is also doing the same thing when hatching closed polylines. The hatch appears outside the selected object and the same distance away as the dimension offset problem. It appears to be linked to object snaps somehow, but I can't find any setting that I can interrogate to try and solve the issue. It only started to do this today on a drawing I have been working on for a week. At a total dead end.
