AutocAD does not have a catalogging feature you can export to MSWord for example, but you can use either PNGOUT command or if you want more control try PLOT command inside each DWG file to crate a PNG or JPG, those drivers should be right there in the pulldown ready for you to use. You can adjust the output settings as needed.
HTH
Look up both commands in HELP to get started.
