AutoCAD LT Forum
Macro for Text Override
7 REPLIES 7
Message 1 of 8
kubaszymanski
446 Views, 7 Replies
Hi All,
is there any way to create a macro that adds the specific text in Text Override value?
I create some buttons that allow me to add prefix/suffix (i.e. below), however, some of my clients require these text addons as text overrides.
^C^C_dimoverride;DIMPOST;Shelf: <>”;;
Could anyone let me know if that is possible?
7 REPLIES 7
Message 2 of 8
hwalker
in reply to: kubaszymanski
No it's not possible. HOWEVER if it's the same override in multiple dimensions why not just select them all and change it in properties (Ctrl+1)?
Howard Walker
Left Handed and Proud
Message 3 of 8
pendean
Most DIM variable changes performed manually (and in macros) appear as overrides in the active DIMSTYLE: test it out.
Then all you need is a simple code like this
^C^C_dimpost;MYSPECIALWORDORLETTERSHERE;
HTH
Message 4 of 8
kubaszymanski
in reply to: hwalker
OK, thank you!
Hehe, I know what it is ;). I'm looking for a solution to avoid spelling mistakes and keep consistency within my team. You know, some clients use "Wall to Centerline: ", others "Rock to CL:" etc. I wanted to create a set of buttons for each workspace to remember a bit less. 😉
Message 5 of 8
kubaszymanski
in reply to: pendean
As I said, I'm not allowed to use suffix/prefix sometimes.
Message 6 of 8
cadffm
^C^C^C_cmddia;0;_dimedit;_new;Shelf: <>";\;_cmddia;1
 or better
^C^C^C_cmddia;0;_select;\_dimedit;_new;Shelf: <>";_p;;_cmddia;1
Sebastian
Message 7 of 8
pendean
@kubaszymanski Then "sometimes" you need to do something else if having multiple DIMSTYLEs is not an option. Yes?
There is no automation for rigid client requirements: buckle to your clients will, or give them up, you can create custom DWT files for each client based on what they provide you as go-bys, presets in place for all their exacting needs (multiple DIMSTYLEs etc.), and only ever use them.
Then train your team over and over and over again to avoid client non-compliance issues: you will need to hire/assign someone as a "compliance officer" for each client and they will need the tools to do client-compliance checks including latest LT versions with DWG and XREF Compare features, and a full AutoCAD seat for access to the CHECKSTANDARDS command too.
It how we all do it.
HTH
Message 8 of 8
kubaszymanski
@pendean Thank you for sharing your thoughts, really appreciated it.  We work exactly as you said. The client always gets what he paid for. I'm just searching for places where I could help my team. It worked with "prefix/suffix" so I'm looking further... It is also a way for me to learn something more.
@cadffm Thank you! This is what I was looking for.
Forma Design Contest
Technology Administrators
