Hi everyone!
I'm trying to make macro which let me change Fill Color in Dimensions to "Background". I'd like to have it as keyboard shortcut.
As a start I create macro to change suffix/prefix, and color but I can't find command for "Fill color". Could anyone help?
^C^C_DIMOVERRIDE;DIMCLRT;4;DIMPOST;%%P<>”;;m;\;
Solved by kubaszymanski. Go to Solution.
I've tried but it seems dimoverride doesn't recognize these two variables.
Commandline: "Variable "DIMTFILL" not found."
As per adding dimstyle. I'm working for different clients. They send me every time new templates, so I'd have to add dimstyles before I start draw.
However, meanwhile I found solution on the other forum.
^C^C$M=$(IF,$(=,$(getvar,DIMTFILL),0),_setvar;DIMTFILL;1;_DRAWORDER;Previous;;Front;,_Setvar;DIMTFILL;0;_DRAWORDER;Previous;;back;)_-Dimstyle;Apply;\;
Yes, I see that.
I thought it will be possible without "getvar" like change of color in my first example.
I'm not so good at DIESEL, need to learn a bit.
