Announcement: We’re aware of an issue affecting starting a new topic from category pages and creating new blog posts. New topics can still be started directly from the relevant board. Learn more here.
lt 2021 hp t2530 print drivers
c_fields
Message 1 of 22
c_fields
went from 2020lt to 2021lt this week and can't get correct driver for a hp t2530 plotter.
Anyone have any suggestions?
Replies (21)
Message 2 of 22
pendean
Community Legend
Community Legend
What does that mean please? What is the problem exactly?
And... Do you have the T2530 driver installed for all of your Windows programs to use?
Message 3 of 22
c_fields
The HP t2530 is a wide format plotter. We have @ 24" wide & a 36" wide roll paper.
Th plotter works fine for other programs. but after installing acad 2021lt I can't find a driver that
uses the correct roll and orientates the plot correctly.
Message 4 of 22
pendean
Community Legend
Community Legend
Forgive me, but how is that any different than LT2020 for you exactly?
In LT2020 did you (or someone for you) create custom PC3 files to use?
Or was it the same system driver all other programs see?
Do other programs see different drivers for "correct roll and orientation"?
In 2021, do you not see the system driver all other programs see?
Message 5 of 22
Biedy
I am having the same issue with 2021Lt and an HP DesignJet T930
Previous Lt versions gave options for size and orientation - for example, I could choose Arch D (landscape) or Arch D (portrait).
2021 Lt you get Arch D and that's it. No orientation choice.
2020 used HP drivers, 2021 uses Windows System drivers. I had my tech guy try to fix things. He was unable to get AutoCAD 2021 to use the HP drivers.  I do not know what steps he tried.
I'm back to 2020.
He suggested I come here for an answer.
Message 6 of 22
pendean
Community Legend
Community Legend
Report your problems with 2021 to Autodesk here https://www.autodesk.com/company/contact-us/product-feedback
Message 7 of 22
pendean
Community Legend
Community Legend
@Biedy not seeing your issue here at all in LT2021 and the HPT930, our driver is installed on the Server and pathed to individual users
Message 8 of 22
Biedy
pendean,
That's exactly what I see here... there's no choice of landscape or portrait.
And I do use that depending on the size of the print and the paper I have loaded.
Anne
Message 9 of 22
pendean
Community Legend
Community Legend
Landscape vs Portrait has never been an option in the driver as a papersize pulldown in LT2017-18-19-20 either here, we've had that plotter that long.
Landscape/Portrait selection has always been available in the drawing orientation section of PLOT command.
EDIT: I forgot to include this screenshot, I would recommend you use this in LT2021, and don't forget to report the issue to Autodesk (see my earlier response to you)
Message 10 of 22
Biedy
2020 Lt vs 2021 lt.
Using the drawing orientation rotates the drawing on the paper, not the paper in the printer.
I have reported using the link you provided, thank you.
Anne
Message 11 of 22
Biedy
Apparently I'm attachment challenged today...
Message 13 of 22
pendean
Community Legend
Community Legend
Thanks for sharing.
Message 14 of 22
c_fields
Since my drivers wants to print the drawings portrait I have changed the paper roll size to allow it to print it vertical.
Message 15 of 22
c_fields
The problem is Not resolved. I have found a way to work around the problem by plotting portrait. But this is a problem when I need to plot something wider than 24". I have to change the paper roll. There has to be a way to plot landscape using  24" &  36" wide roll paper.
Message 16 of 22
pendean
Community Legend
Community Legend
Does plotting to PDF also exhibit this problem? If not, does printing that PDF to the plotter create the issue or avoids it?
Autodesk Support may be what you need next, from your Autodesk Account Page here https://knowledge.autodesk.com/contact-support
Then... HP support forums are over here https://h30434.www3.hp.com/
Autodesk feedback for 2021 issues is here (if this works for you in older versions) https://www.autodesk.com/company/contact-us/product-feedback
Message 17 of 22
c_fields
plotting pdf does have the same problem
Message 18 of 22
pendean
Community Legend
Community Legend
Show us: screenshots and photos please of what you see from the plotter and why it is wrong, a copy of your "not correct" PDF, a DWG file set up to output to PDF that is "not correct".
But before hand, read post #9 above from me and ensure your problem is not just a paper orientation problem between your paper selection and what you are asking AutoCAD to rotate as well. Also read post #12 about paper sizes in plotter drivers.
Message 19 of 22
MichaelGibson5012
Have you tried going to the windows devices and printers and check the settings autorotate? which should rotate to what paper is installed to save on paper etc?
Message 20 of 22
Biedy
Yes, and it's still a crapshoot if it will print correctly.
