Message 1 of 22
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
went from 2020lt to 2021lt this week and can't get correct driver for a hp t2530 plotter.
Anyone have any suggestions?
The HP t2530 is a wide format plotter. We have @ 24" wide & a 36" wide roll paper.
Th plotter works fine for other programs. but after installing acad 2021lt I can't find a driver that
uses the correct roll and orientates the plot correctly.
I am having the same issue with 2021Lt and an HP DesignJet T930
Previous Lt versions gave options for size and orientation - for example, I could choose Arch D (landscape) or Arch D (portrait).
2021 Lt you get Arch D and that's it. No orientation choice.
2020 used HP drivers, 2021 uses Windows System drivers. I had my tech guy try to fix things. He was unable to get AutoCAD 2021 to use the HP drivers. I do not know what steps he tried.
I'm back to 2020.
He suggested I come here for an answer.
pendean,
That's exactly what I see here... there's no choice of landscape or portrait.
And I do use that depending on the size of the print and the paper I have loaded.
Anne
Landscape vs Portrait has never been an option in the driver as a papersize pulldown in LT2017-18-19-20 either here, we've had that plotter that long.
Landscape/Portrait selection has always been available in the drawing orientation section of PLOT command.
EDIT: I forgot to include this screenshot, I would recommend you use this in LT2021, and don't forget to report the issue to Autodesk (see my earlier response to you)
2020 Lt vs 2021 lt.
Using the drawing orientation rotates the drawing on the paper, not the paper in the printer.
I have reported using the link you provided, thank you.
Anne
Since my drivers wants to print the drawings portrait I have changed the paper roll size to allow it to print it vertical.
The problem is Not resolved. I have found a way to work around the problem by plotting portrait. But this is a problem when I need to plot something wider than 24". I have to change the paper roll. There has to be a way to plot landscape using 24" & 36" wide roll paper.
Have you tried going to the windows devices and printers and check the settings autorotate? which should rotate to what paper is installed to save on paper etc?
