AutoCAD LT Forum
Welcome to Autodeskā€™s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
Showing results forĀ
Did you mean:Ā
Losing lines when solid hatching.
20 REPLIES 20
Message 1 of 21
11087 Views, 20 Replies
Hi, I am a very non technical self taught user at a basic level. I have created an isometric drawing in 2D. I then hatch planes with a solid pattern and I then lose some of the lines. There is hatching on both sides of the lines and the lost lines appear to be completely random. Any suggestions please?
20 REPLIES 20
Message 2 of 21
pendean
Show us what you mean: post your DWG file and add notes in it explaining the problem.
Message 3 of 21
in reply to: pendean
Hi and thanks for the reply.
Please see file attached and note the vertical line in bottom left corner as not being visible. This also shows as hidden when i print to pdf etc.
Message 4 of 21
bob_mpc
Select all your lines (click on one and then right-click -> Select Similar), it will select all LINE objects in this layer, and then - (MENU): Tools -> Draw Order -> Send to front. It will display them on top of other layers. It is in HOME-MODIFY pallete in the Ribbon.
BTW, it is not good practice to draw in layer 0.
Boris
AutoCad LT 2021.1.1
Message 5 of 21
in reply to: bob_mpc
Again, Thanks for help.
I have changed the lines to a different layer and brought them all to the front as instructed. Assuming that the lines should then be visible on the screen the action of bringing them to the front has not worked and in fact I have even fewer outline lines visible. Result attched.
Am I doing something wrong?
Message 6 of 21
drjohn
I call BS on that statement.
Message 7 of 21
bob_mpc
In the two screenshots attached is what I see when opening and after applying "send to back".
BTW, I missed something - sorry. There is (at least in 2013) "HATCHES TO BACK" option. See the screenshot.
Boris
AutoCad LT 2021.1.1
Message 8 of 21
bob_mpc
in reply to: drjohn
What does BS stand for? Sorry, I am not native English speaker.
Boris
AutoCad LT 2021.1.1
Message 9 of 21
pendean
in reply to: drjohn
A little immature of a response there @drjohn: you probably meant to say
"drafting on layer 0 is an option but most users prefer to leave that layer blank as it is more of a control layer that can affect the behavior of other objects".
Message 10 of 21
pendean
Which lines are you "losing" exactly? Neither your latest CAD file nor those screenshots tell me much sadly, I am at a loss on what you actually wish to achieve.
Message 11 of 21
drjohn
@pendean wrote:
@A little immature of a response there @Anonymous
Pot / Kettle?  Smiley Happy
Message 12 of 21
pendean
in reply to: drjohn
Most likely, but we ought to do better.
Message 13 of 21
bob_mpc
@pendean wrote:
@A little immature of a response there @Anonymous: you probably meant to say
Yes, that is what I meant. And I state this due to personal expirience! It is absloutely true when someone else will use this drawing - for example as an XREF to be underlayed - it almost completely destroys any option to manipulate the layer properties! You cannot even freeze it. So, it is not BS (if it means bullsh..). Maybe I had to explain better what I meant.
Concerning the problem of the OP - if you look at "Before" screenshot you will see that some of the bricks don't have contour line. They are, for some reason, behind the yellow hatch.
Boris
AutoCad LT 2021.1.1
Message 14 of 21
pendean
I see it now: thank you for the follow up.
Message 15 of 21
stevetamplen
@Anonymous
Did any of the posts get your problem resolved? If so, please hit the Accept as Solution button so that more community members can profit from the solution.
If not, please post back and I (and the rest of the Community) will be happy to continue assisting you!
Steve Tamplen
Technical Support Specialist
Message 16 of 21
stevetamplen
in reply to: stevetamplen
@Anonymous
Are you still having issues? If so, please post back and I will be happy to continue assisting you!
Steve Tamplen
Tags (1)
Message 17 of 21
stevetamplen
@Anonymous
I did not hear back from you, so I marked two of the posts as Accepted Solutions. This is so that more Community members can profit from the solution.
If you disagree, or if you need more help, please post back and the Community and I will continue to assist you.
Steve Tamplen
Message 18 of 21
Tha is I didnā€™t know that !
Message 19 of 21
I am running into the same exact problem when drawing rectangles with a hatch inside of it, I tried to bring the lines forward using the steps given previously, and the only thing that changed is that I now I have fewer lines
Message 20 of 21
steven-g
Post a dwg file so we can see the problem.
Forma Design Contest
Technology Administrators
