LOCAL CHANGE TO THE DIMENSION STYLES IS AUTOMATED
This widget could not be displayed.
GOOD MORNING, I HAVE A PROBLEM: EVERY TIME I OPEN THE DRAWING, A LOCAL CHANGE TO THE DIMENSION STYLES IS AUTOMATED. HOW CAN I AVOID IT WITHOUT HAVING TO ANNOTATE IT EVERY TIME AND DELETE IT?
cadffm
>>"GOOD MORNING, I HAVE A PROBLEM: "
Is it your CapsLock or your Shift-Key?
>>"A LOCAL CHANGE TO THE DIMENSION STYLES IS AUTOMATED."
Which product?
Share a picture of the command: ABOUT dialog.
>>"HOW CAN I AVOID IT WITHOUT HAVING TO ANNOTATE IT EVERY TIME AND DELETE IT?
What do you mean with "WITHOUT HAVING TO ANNOTATE IT EVERY TIME AND DELETE IT?" exactly,
which steps you gave to do when open an existing drawing?
If you talk about AutoCAD 2014&newer: Start ACAD for a test in /safemode
http://help.autodesk.com/view/ACD/2021/ENU/?guid=GUID-8E54B6EC-5B52-4F62-B7FC-0D4E1EDF093A
Same issue?
Sebastian
RobDraw
 LOL!
Rob
