Show only
Search instead for
Do you start LINE command, click for a start location on screen, pull the cursor in the direction you want, then type 30 in the box and hit <enter> on the keyboard? Or are you doing something else? is the problem just in this one file, or all files?
Can you post a copy of your command history (press F2 and use Ctrl+c to copy the part of the history from when you start the line command) and also a copy of a dwg file with a line so we can see the line you are talking about.
