Beginner user, 64 bit laptop, Windows 10 V1803. Autocad LT 2018. I have always had trouble with Line Command when performing the following: Line>select starting point> try to enter inches with fraction of inches. Drawing Utilities>Units> architectural>precision> up to 1/4inch. Model 1:1. I enter number with ft symbol, then dash then inch and fraction of inch. Visual measure block turns blue & nothing is executed. Why? Works fine with whole number of FT & whole inches only. Also when dragging line from start point, lowest fraction is at 1/2in. Not 1/4 in.
Solved by pendean. Go to Solution.
Thank you for the info. I did change the setting to 1/4" for the ossnap grid. It was set at 1/2", thus now when dragging a line segment the dimension is accurate. Still, if I follow the steps, I cannot get the chosen dimension ( that I entered ) to create the correct length of the line segment. So I : Line command>lt click start point>drag line(numeric values populate)>I enter in the box a single linear dimension such as 3'-11/4>enter> result is a line segment with a dimension Not equal to 3'-11/4 ( that's 3ft 1 and 1/4" ) ( Autodesk states that you can either use the ", or not, when the ' is used).
This is so simple...what is wrong w my workflow?
