AutoCAD LT Forum
Leader Automatic Text Mask
2 REPLIES 2
agrimmRU4TK
244 Views, 2 Replies
I see several posts but was looking for something current to the AutoCAD LT 2021 version.
  • When I make a new leader can I have it automatically text mask, so I don't have to go back and change them in the properties box afterwards?
2 REPLIES 2
pendean
in reply to: agrimmRU4TK
There is no "automatic mask" setting in MLEADERSTYLE command, a requirement for what you wish to happen. But you can set one to be just that, place it in a Toolpalette, then drag/drop and reuse that as often as you need (COPY and copy/paste are other methods to reuse an already edited Mleader with that setting).
agrimmRU4TK
Okay thank you...
Our designers have been asking this question, and don't want to edit after.
The idea we are going for is to use less clicks/steps to get the desired result.
Forma Design Contest
Technology Administrators
