Layer Auto Select
Layer Auto Select
Theo_ST
Message 1 of 10
Layer Auto Select
Theo_ST
Hi All,
I recently transitioned from working on a mac to a PC (AutoCAD LT 2022)
On my mac, when I selected an object, it would automatically highlight the selected layer in my layers panel. On the PC, it doesn't do that. Any suggestions on how I can do this?
Thanks in advance.
Replies (9)
Message 2 of 10
ВeekeeCZ
The only way is actually to make the layer current. LAYCUR command.
Message 3 of 10
Theo_ST
Thanks. It doesn't seem to be working as the object is on an xref file. I'll have to do it the painful way I guess. 🙂
Message 4 of 10
pendean
Community Legend
Community Legend
What are your settings for PICKFIRST and PICKADD? Look them up in HELP, the default settings listed there are preferred.
Message 5 of 10
Patchy
It never shows on Prop. Pallet if it's in an xref.
You have to use command XLIST.
Message 6 of 10
jrreid
Message 7 of 10
Kent1Cooper
@jrreid wrote:
Found this LISP ....
[Message 1 indicates they're using AutoCAD LT, so AutoLisp functions are not an option.]
Kent Cooper, AIA
Message 8 of 10
jrreid
My bad. Missed the LT. I personally would never work at somewhere that has people using LT.
Upgrade is a must!! The Monthly payments will never bust their budget.
Message 9 of 10
pendean
Community Legend
Community Legend
>>>....The Monthly payments will never bust their budget....<<<
@jrreid you'd be amazed at the thin margins some users have to operate under at their job.
Message 10 of 10
maxim_k
Hi @Theo_ST ,
In AutoCAD LT for Windows you can use QAT (Quick Access Toolbar) for this purpose:
https://knowledge.autodesk.com/support/inventor-lt/learn-explore/caas/CloudHelp/cloudhelp/2021/ENU/I...
Just add Layers list to it and as soon as you select an object its layer will be on the first place in this list.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
