Creating a viewport automatically adds viewport scale to all annotative objects
moe4082
moe4082
It seems like recently, when I create a new viewport, say at 1/8" per foot scale, CAD is automatically adding the 1/8" per foot scale to all annotative objects (text, dimensions, & leaders).
This does not work for me as I use multiple different scales in the same DWG file and sometimes allow annotative items to show even though they do not match the viewport scale.
Is there a way to turn this off?  I am running 2021 LT.
h_s_walker
Make sure that the icon ringed in the image below is grey (NOT activated)
Howard Walker
Left Handed and Proud
moe4082
Perfect. Thanks!
Hi Moe,
I'm curious to know if you had to remove and replace all of these objects, after you turned the annotative scale setting off, as was suggested.
I had the same problem, but when I turned off he "Add scales" annotation setting, none of the blocks, dims, test or other objects reset.
Hope to hear back
cheers
moe4082
Unfortunately I did not find a way to remove the extra scales without selecting the objects, opening the properties, and editing which scales were associated to the objects.
I caught it early enough that it only caused me a problem on 1 dwg file and didn't pollute all of my files.
