Show only
Search instead for
Migrated from 2007 LT. Ever since the snap to seems to be erratic. It almost seems as if it snaps "close to" the point/intersection/center/quadrant that I want. Also, I draw a lot of electrical drawings and use a half circle as jump overs. Draw circle diameter .05 on intersection of two wires. Use appropriate trimming options to make semi circle and to break one of the wires. Problem is when I copy from center of semi-circle to a new intersection, the semi circle seems to be rotated by some very small amount, an amount that screws up the subsequent trimming.
1. what is your AUTOSNAP system variable set to? 2. Sounds like your UCS and/or PLAN variable are rotated in this one file, perhaps not set to WORLD for both. This may be the other issue if all of this is in a single DWG file.
