Migrated from 2007 LT. Ever since the snap to seems to be erratic. It almost seems as if it snaps "close to" the point/intersection/center/quadrant that I want. Also, I draw a lot of electrical drawings and use a half circle as jump overs. Draw circle diameter .05 on intersection of two wires. Use appropriate trimming options to make semi circle and to break one of the wires. Problem is when I copy from center of semi-circle to a new intersection, the semi circle seems to be rotated by some very small amount, an amount that screws up the subsequent trimming.
Solved by pendean. Go to Solution.
