IF SO... WHAT IS THE COMMAND FOR THAT?
Solved by Emmsleys. Go to Solution.
Solved by pendean. Go to Solution.
I haven't personally come across a lot of threads that mentioned Bluebeam, it might be best for you to also post in their forums for additional support.
Not sure about BlueBeam, but check out this article:
How to convert a PDF to a DWG in AutoCAD (autodesk.com)
If it's a vector PDF, AutoCAD can import and convert it to linework.
