Vertex moving isn't working as it should
giannisYAV7U
giannisYAV7U
Hi all,
I've been having a problem with vertex editing since I upgraded to Autocad lt 2025.
When i select a line segment and try to move it by typing a distance less than 0.06m, it doesn't move or it snaps to a close-by vertex. Everything above 0.06 works as it should.
When selecting a vertex to move it a set distance, typing the distance will not move it towards the chosen direction but will change the size of an adjoining line segment. I have to press Tab 5 times for the input to become "distance from first point". This has never worked like that in the past
I'm not 100% sure if it happens always, but I believe it does.
This has been happening for consecutive days, with shutdowns and restarts, across different projects/files, since I upgraded
My units are set to meters with precision of 0.000
My input settings below
Yiannis
pendean
Community Legend
Community Legend
@giannisYAV7U wrote:
...I'm not 100% sure if it happens always, but I believe it does....
There are only fixes for "always", next time it happens share a DWG file over here for us to try it too.
In the meantime... Have you installed the 2025.1 Update yet? It's new, ABOUT command inside your AutoCAD will confirm what you have installed. If not, get it from your Autodesk Account Page here https://manage.autodesk.com/cep/#products-services/updates
Restart your PC afterwards.
If that did not help... Set GFXDX12 variable to 0 (that's a zero) then restart AutoCAD.
If still no relief then start GRAPHICSCONFIG command and change the 2D Display Settings pulldown from "advanced mode" to one of the other choices.
If all else fails, then turn off Hardware Acceleration as a last resort, and start a support ticket through your subscription portal as explained here
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/How-to-find-my-sup...
HTH
giannisYAV7U
Hi @pendean.
Thank you for the reply!
It happened 100% on my computer. I didn't upload the file because the problem wasn't reproducible in other computers (with the same license, same version). I'm on version 2025.0.1, going to update
I unchecked and rechecked all of the settings that seemed relevant to the problem, and it was briefly solved. After 10 minutes the problem returned 😑
I'll get back soon as I try your solutions
Thanks again,
Yiannis
