hello
I was used to inserting georeferenced aerial images in AutoCAD Civil 3D, but now I have switched to AutoCAD LT (MAPIINSERT command).
How can I do the same process in AutoCAD LT? is there any way?
hello
Solved by rkmcswain. Go to Solution.
@Anonymous -- Have you checked out the AutoCAD LT documentation on this?
AutoCAD LT does not include the mapiinsert command. That command is part of AutoCAD MAP.
