AutoCAD LT Forum
Insert georreferenced Aerial image
5 REPLIES 5
1927 Views, 5 Replies
hello
I was used to inserting georeferenced aerial images in AutoCAD Civil 3D, but now I have switched to AutoCAD LT (MAPIINSERT command).
How can I do the same process in AutoCAD LT? is there any way?
hello
Labels (3)
5 REPLIES 5
rkmcswain
rkmcswain
 @Anonymous  --   Have you checked out the AutoCAD LT documentation on this?
R.K. McSwain     | CADpanacea | on twitter
in reply to: rkmcswain
I think it will not be the same. i have a raster geotiff with world file (tfw) and the command mapiinsert reads the raster coordinates and place it automatically in the correct (projected) map coordinates.
rkmcswain
rkmcswain
AutoCAD LT does not include the mapiinsert command. That command is part of AutoCAD MAP.
pendean
pendean
Community Legend
Community Legend
Friend, you are comparing $2300/yr dedicated civil/mapping C3D to $400/yr general use not-designed-to-any-specialty LT, so yes, the abilities are going to be drastically reduced by a significant amount.
If you need C3D or Map3D for your tasks, its time to upgrade (or convince the boss to upgrade).
Good luck.
Good luck.
in reply to: pendean
Thanks, I'm going to solve the problema in other way.
Technology Administrators
