Imported text does not appear when I DXF the file, need help. Cannot explode my text.
Problem is that I cannot get my text to appear when I DXF out. I have imported text from an excel file with first column being "-TEXT", then "X,Y" data point, with next column being "Angle" and finally the "Text" to appear on screen. When I paste this in AutoCAD it works great and goes exactly where I need it to. I found out that this is most likely not appearing on my DXF files due to it being in block format and needing to explode it in order to get it in vector form. Problem is I try to explode it says "1 was not able to exploded".
I have tried:
-changing my text font to dim.shx for straight lines instead of bubble letters
-changing my text from annotative to standard
-to change in the block editor - properties tab to allow exploding
-turning "use big font" off
-Checking off the "Annotative" in text style
-quick selecting text and turning "annotative" in properties to no
None of this seems to work. If anyone has any ideas it would be greatly appreciated.
