AutoCAD LT Forum
Welcome to Autodesk’s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
Imported Survey Points come in mirrored & upsidedown
1 REPLY 1
1miguel
1144 Views, 1 Reply
I have some test survey points, they are supposed to plot like the image shows on the right (green dots, red line). But when i bring the points into autocad lt they come in reversed (image on the left) what am i doing wrong? I've tried reversing the coordinates placing y numbers in the x column but nothing. I've also attached the excel file for reference. i insert the points using the scripted noted below
_MULTIPLE _POINT
0.41,-2.82,0.05
98.54,-311.21,7.96
143.37,-459.95,-20.65
333.72,-603.51,8.48
432.16,-447.74,-4.82
527.23,-293.52,1.33
400.36,-212.08,-32.41
246.66,-116.02,-27.64
0.41,-2.82,0.05
170.9,-100.42,-16.77
110.06,-199.41,-12.27
65.16,-278.65,-9.1
160.14,-412.5,-21.63
240.22,-336.36,-27.09
314.3,-276.4,-32.33
420.99,-306.69,-14.36
352.72,-390.33,-15.09
265.78,-477.28,-14.48
Labels (1)
1 REPLY 1
steven-g
in reply to: 1miguel
Not everyone uses the same coordinate system, it looks like your survey data is using the Y axis in a downwards direction. If you remove the minus sign from the Y data then it plots 'Visually' correct. But you should check with your surveyor as to how the data should be read.
Forma Design Contest
Technology Administrators
