AutoCAD LT Forum
Import
4 REPLIES 4
t_leis
312 Views, 4 Replies
Import
Can points from a total station be imported into the LT version of autocad?
4 REPLIES 4
hwalker
in reply to: t_leis
If Total Station can save the data as a DXF file, then LT can open it
Howard Walker
Left Handed and Proud
steven-g
in reply to: t_leis
Or if it can export just the point coordinates to a CSV file, then you can turn that into a script in Excel
Emmsleys
in reply to: t_leis
What version of Total Station are you using and what version of AutoCAD LT are you using?
Sarah Emmsley
Technical Support Specialist
Emmsleys
in reply to: Emmsleys
Checking with my previous post if you have any questions or found a workaround post back.
If you still need help or have questions I'll be more than happy to help.
Thanks.
Please select Accept as Solution if my post or any other post in this thread resolves your issue, or reply with additional information if the problem persists.
Sarah Emmsley
Forma Design Contest
Technology Administrators
