@Anonymous
When I work in other drawings I normally use the following steps to clean up the file before I add any new edits to the project. This is just a process I use, this may be helpful since you are not the original creator of the files and multiple drafters may need to make edits to the same project.
1. Run RECOVERALL, at the command line and select drawing, save drawing and close.
2. Run RECOVER, at the command line and select drawing.
3. (-)PURGE > Regapps > Enter>No
4. (-)PURGE>ALL> Enter>No
5. AUDIT> Yes
6. PURGE > Select Purge nested items> Select Automatically purge orphaned data > Purge All
7. CTRL+A > OVERKILL
8. Close and Save newly purged file (ex. CLEANED_file)
9. Apply workflow.
I also hyperlinked the commands so that you can read in further detail of each one. Like dean had mentioned the "-" is intentional and necessary. I would run through Deans steps as well as the ones above.
Please select"Accept as Solution" if my post or any other post in this thread resolves your issue, or reply with additional information if the problem persists.
Sarah Emmsley
Technical Support Specialist
