AutoCAD LT Forum
Welcome to Autodesk’s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
how to plot several layouts on the same page?
5 REPLIES 5
586 Views, 5 Replies
I have several layouts to plot on a roll (plotter). Each layout is only 297mm high. So i there is space to plot up tot 3 layouts above eachother. Now i have to plot each layout seperate from eachother and lose 2/3 of the paper. Is it also possible to do the same plot with layouts from differtent DWG's? I use autocad LT 2017.
Tags (3)
5 REPLIES 5
h_s_walker
Welcome to the Forums
Don't think it can be done by AutoCAD. Is there not a setting in your printer which says do multiple prints per page?
Howard Walker
Left Handed and Proud
bob_mpc
You can just copy and paste the contents of the three layouts in one new layout.
I don't think it can be done on different drawings, however.
Some plotters might have this option, but it is the plotter, not the PC.
Boris
AutoCad LT 2021.1.1
pendean
You have to manually create what you want in a single layout tab with multiple viewports.
Or PLOT to PDF then use your printer/plotter driver's ability to do that if one exists there in that driver.
Emmsleys
Hi @Anonymous,
I see that you are visiting as a new member. Welcome to the Autodesk Community!
It appears that several folks have tried to help on this issue. Were you able to find a solution? Or a workaround?
Did any of the posts in the thread help with your issue?
Please select Accept as Solution if any post in this thread resolves your issue, or reply with additional information if the problem persists.
Sarah Emmsley
Technical Support Specialist
Emmsleys
Checking back with you, post with any new updates if you need continued help on your thread.
Thanks for your time.
Sarah Emmsley
Technology Administrators
