How to extract all the info in the command line
jscolesVWCD9
jscolesVWCD9
I've been searching for a way to get a total sum of all the polylines in my drawings. I know there aren't any features in LT however I found this post where one user attached an excel spreadsheet to do all the work. Solved: How to measure total length?! - Autodesk Community - AutoCAD LT
The issue I'm having is I use the list command but by the time it's processed all the polylines, the first half have disappeared off the top. Is there a way I can use the list command and extract all the results without losing the first half?
pendean
Community Legend
Community Legend
CTRL+F2 on your keyboard will give you access to the full commandline list that you can scroll up and down to get the info you want. You can copy/paste from there too.
To "extract" to a text file you need to turn on the log file feature (then turn it off) as it records everything: LOGFILEON and LOGFILEOFF commands are explained in HELP.
HTH
jscolesVWCD9
Thank you that's perfect. Ctrl F2 didn't let me scroll up the command list any higher but logfileon worked brilliantly.
pendean
Community Legend
Community Legend
>>>... Ctrl F2 didn't let me scroll up the command list ...<<<
Did you use the mouse wheel to scroll up? I can go back quite bit in my DWG files all the time.
jscolesVWCD9
Yeah I can scroll up to the top but it still cuts off half the text. I did use the list command on a lot of long polylines though.
