AutoCAD LT Forum
Welcome to Autodesk’s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
How do I select multiple layer at one time?
2 REPLIES 2
16137 Views, 2 Replies
I often need to copy lighting design layers from outdated to updated
drawings for my clients. How can I select mutiple layers at the same time,
so that I don't have to redo the Quickselect process selection steps 5 or 6
times ? I set a up a layer group, or filter, but it doesn't seem to have
value for multiple layer selection.
Mike Noon
2 REPLIES 2
I would just freeze all the layers I didn't want then select the whole drawing and copy and paste it rather than transferring each layer individually as all the new layers get inserted in the same way in the new drawing.
FILTER command will let you select as many layers as you
want for a one time selection method too.
As well as Nickha's idea, the other easier way to do it.
Dean Saadallah
Add-on products for LT
http://www.pendean.com/lt
Forma Design Contest
Technology Administrators
