hogs / file is slow to open
10,000kb but file is slow to open
pendean
Community Legend
Community Legend
Not enough information: try to add more details, post a screenshot of your ABOUT command, PC/Laptop specs, where you store the file, how are you connected to that file location, and if this is the only file with problems and what you did to fix it.
rkmcswain
@Anonymous  --- this ^^^^
Do that first.
Grab LANSpeed from here, and then test the LAN/WAN speed from your PC to the location where the file is stored. The vast majority of time, this is where I find a problem. A bad network cable, bad IP phone throughput, bad port, etc.
filipefrancisco
Try an AUDIT and a PURGE to try solve the problem
Filipe Francisco
Comunidade Autodesk - Português - Colaborador
Autodesk Certified Instructor | AutoCAD Certified | Revit Architecture Certified | Autodesk Expert Elite
YOUTUBE | LINKEDIN
Se a resposta resolveu o seu problema, clique em Aceitar como Solução isso ajuda os outros usuários a encontrar rapidamente uma resposta e Curta se gostou.
If the answer solved your problem, click Accept as Solution. This helps other users to quickly find an answer. And hit Like if you do.
Autodesk Community
