Help with Move command in AutoCad LT 2025 version
pushkardighe
Observer Observer
Message 1 of 9
pushkardighe
Observer
Observer
Hi All,
I need to do the following with my move command.
Say I have selected the object and used point at "A" which is say at 0,0 absolute coordinate as the base point to move.
From here I will select another point say point "B" at 10,10 absolute coordinates but this point is not my destination point but a "reference" point.
I need to move the object to point "C" say which is at distance of 2,2 from the reference point B and no relation to point A. I will be using Object snap when selecting points A and B.
This has to happen in a single move command and I should not have to move the object 2 times. Is this possible in AutoCad LT?
Thank you,
Pushkar Dighe
Replies (8)
Message 2 of 9
cadffm
>"From here I will select another point say point "B" at 10,10"
Before you type in "10,10", send FROM
Point A
From
Point B
Relative coordinates to Point C
Sebastian
Message 3 of 9
RobRocks
@pushkardighe wrote:
Say I have selected the object and used point at "A" which is say at 0,0 absolute coordinate as the base point to move. ?
Skip this step.
This should be your base point.
Then why did you pick point A as your basepoint? Pick point B as base and the point C as the destination point.
You won't get where you want.
Yes.
Message 4 of 9
pushkardighe
Observer
Observer
Hi All, thanks for your suggestion, but that is not it. I have attached a ppt file with couple of slides and images to explain the problem in better way hope this helps clarifying my question in better way.
Thank you,
Pushkar Dighe
Message 5 of 9
RobRocks
I would do it with object snap tracking.
Message 6 of 9
h_s_walker
@pushkardighe @cadffm gave you the information you need.
Select to sofa to move and use it's insertion point as your base point then use the FROM snap to choose the corner of your other sofa and type in @-2,2 which will put one sofa 2 units to the left and 2 units above the other sofa
Howard Walker
Left Handed and Proud
Message 7 of 9
pushkardighe
Observer
Observer
Thanks a lot @h_s_walker for your support this really helps me a lot.
Thank you,
Pushkar Dighe
Message 8 of 9
RobRocks
Your welcome.
Message 9 of 9
RSomppi
If you haven't done it already, Object Snap Tracking is very useful for many situations. I suggest at least having a look at this versatile tool that should be in everyone's tool box.
