In AutoCAD LT 2017, the help displays in English but prints out in some other language. The help window shows "English" in the language selection drop down. How can this be fixed.
Solved by WarrenGeissler. Go to Solution.
That's pretty unusual. A workaround is to download and install the offline HELP and disable using online content in OPTIONS. You are able to print from that.
Warren Geissler
Drafting Manager Denver Water
_____________________________________________
Please ACCEPT AS SOLUTON if this works
(...and doesn't melt your computer or cause Armageddon)
I have this problem on two different machines running LT 2017.
The offline help does not seem to be as comprehensive as the online help. I only found the content I was looking for using the online help, but you can see what happens when I try to print. I did, however, discover that when I right click on the link to the content, and pick Open in Browser, it takes me to the Technical Support page where I can view and print the content.
Thanks for your help.
I was running into the same thing - good catch on opening the help in Browser!
Warren Geissler
Hi @chasbo4,
Is this happening non all help pages or just specific ones? How are you printing the page (which driver/printer)? I have tried this from my computer and can't can duplicate the issue. I tired a couple different PDF drivers and both gave me this result. The error appears to only be happening in-product. I will bring this to the attention of the team.
HI @chasbo4,
Thanks for bringing this to my attention. I have notified the team so they can investigate. It appears to only be an issue in AutoCAD LT 2017 when printing from in-product Online Help. Printing from the web help or from offline help should work properly.
Actually I can recreate with all the 2017 products (AutoCAD based at least)
Warren Geissler
