Hatch selection questions
DartGTDan-2018
DartGTDan-2018
I have a box constructed of 4 black lines (an exploded rectangle).  I can add any color (gray in this case) hatch using any pattern to the interior of the box.  All is good and working as expected to this point.
However, I now want to change the existing color (gray) of the hatch pattern to some other color.  I move the cursor and select (left click) the hatch pattern on the interior of the box (avoiding the 4 perimeter lines (no window selection done here)).  The properties dialog box now shows "Color" = "VARIES" (indicating, to me, that more than 1 object (the hatch pattern) was selected).  It appears by selecting (left click) the hatch pattern the perimeter shape lines are included.  Also, if I select the hatch pattern to delete it, the perimeter shape lines are deleted too.
Why does selecting the hatch pattern also include the perimeter shape lines (any shape, any number of lines, exploded or PEDIT Joined)?  Is there a hatch selection setting to control this?
pendean
Community Legend
Community Legend
You forgot to turn off hatch association with it's boundary most likely for part of your issue. What else did you skip over in the HATCH command pop-up? Can you show us in a screenshot?
Any reason you cannot share that portion of that DWG file with the problem in it for others to touch/examine? That would help too.
DartGTDan-2018
Sample drawing is attached.
pendean
Community Legend
Community Legend
THanks for the file: this needs to say NO if you don't want your hatch and its boundary to be tied together
I don't see where your hatch lists color as "varies" in your posted file, do you?
DartGTDan-2018
pendean,
That worked!  Thank you!
The attached image shows the properties box before your solution.
