Align, scale objects on alignment points
ruiterCV8G6
ruiterCV8G6
Hello all,
This strange thing happens to me...
When I align an object to a line and select 2 seperate base points and target points to align to and enter (continue) we all get the question "Scale objects based on alignment points?". I enter NO, because I don't want to change the dimensions of the object in question.
I've had several issues with this command that it DOES change the dimensions of the object. It are only small deviations for example 15670 becomes 15662,37.
Does anyone have the same issues? And what is the problem?
pendean
Community Legend
Community Legend
Show us with a sample DWG file with the problem, explain how we can replicate it in detail.
And explain in very uncertain terms how you are measuring 15670 vs 15662,37 as often that is the underlying problem if the change in object orientation is not factored in by the user.
h_s_walker
What version of LT are you using?
Is it updated to the latest version?
Howard Walker
Left Handed and Proud
ruiterCV8G6
2022. I have 2023 but dit not check the problem in this version yet.
h_s_walker
No problems in LT2016. I would suggest you get the patches and then try again
Howard Walker
ruiterCV8G6
I tried to recreate the same problem by doing what I always do..... Now it doesn't do the problem that I have.
Will keep it under investigation.... Sorry
h_s_walker
Don't apologise. We're just users like yourself. We are all fallible
Howard Walker
