AutoCAD LT Forum
Welcome to Autodesk’s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
Hatch Problem
5 REPLIES 5
360 Views, 5 Replies
Hatch Problem
Hi There,
I am having an issue with Hatch using Autocad LT 2016.
I have several hatches on my drawing, with only one showing up in paper space. I cannot locate why, as I created all the hatches the same way, no changed settings.
When I select my view port I can select the hatch and see that it is there, however as soon as I unselect the viewport it disappears again.
Can anyone tell me what command I am missing to get all the hatches viewing properly in  paper space?
Thanks!
5 REPLIES 5
steven-g
Can you post the drawing it could be several things, do you use annotative hatching in which case it could be an annotative scale issue, maybe a viewport layer overide in the color settings, do the hatches all appear ok in model space ?
Emmsleys
It might be easier if you are able to post a drawing or create a screencast of your problem with hatching.
Screencast is a free application you can download it from here: https://knowledge.autodesk.com/community/screencast
Sarah Emmsley
Technical Support Specialist
in reply to: steven-g
I did try turning off Annotative, read that may be the cause, but no luck there. The hatches do appear in model space. How best to post the drawing - just upload the dwg file with the issue? Thanks for the help BTW 🙂
steven-g
Yeah just upload it, also make sure this button is active, it will show all annotative objects.
The variable is "annoallvisible"
Emmsleys
Following up on your thread,select Accept as Solution if any post answered your questions.
 If you still have any new questions post back.
Sarah Emmsley
Technology Administrators
