Hi There,
I am having an issue with Hatch using Autocad LT 2016.
I have several hatches on my drawing, with only one showing up in paper space. I cannot locate why, as I created all the hatches the same way, no changed settings.
When I select my view port I can select the hatch and see that it is there, however as soon as I unselect the viewport it disappears again.
Can anyone tell me what command I am missing to get all the hatches viewing properly in paper space?
Thanks!
It might be easier if you are able to post a drawing or create a screencast of your problem with hatching.
Screencast is a free application you can download it from here: https://knowledge.autodesk.com/community/screencast
I did try turning off Annotative, read that may be the cause, but no luck there. The hatches do appear in model space. How best to post the drawing - just upload the dwg file with the issue? Thanks for the help BTW 🙂
Following up on your thread,select Accept as Solution if any post answered your questions.
If you still have any new questions post back.
