AutoCAD LT Forum
Welcome to Autodesk’s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
Group Function Not working
17 REPLIES 17
Message 1 of 18
45993 Views, 17 Replies
ACLT2000 on a Windows XP machine.
In the last day, one of our users has lost his ability to Group. Whether he
selects objects and then pulls down "Group" from the tools menu or vice
versa, the objects do not group. The command line text doesn't give any
errors or other indication of what is happening.
Any leads appreciated....
- Steve
17 REPLIES 17
Message 2 of 18
pendean
PICKSTYLE variable, explore it in HELP.
Dean
Message 3 of 18
Are you sure grouping is turned on?
ctrl+shift+A turns the group function on/off
Message 4 of 18
Thank you, The Ctrl-Shift-A fixed my issue with grouping.
Message 5 of 18
I happened to randomly past this answer with the same problem, thanks for this. Have a lovely week!
Message 6 of 18
I am having a similar problem, but the 'group' function does not exist on my mouse.
I have tried ctrl+shift+A but this does nothing.
How do l change my settings to put 'group' back onto my mouse command?
Message 7 of 18
pendean
Which LT version?
Do you have the RIBBON on or off?
Did you look up GROUP command in HELP to see how it works and where to find it?
CTRL+SHIFT+A toggles PICKSTYLE variable on/off, it has nothing to do with starting any group command or function. Explore PICKSTYLE in HELP, you want it to stay on if you want to use groups.
Message 8 of 18
thank you. I also had this same problem. Grouping is a time saver for me and losing it was causing great frustration. Thanks for posting the solution. Ctrl- Shift -A!
Message 9 of 18
Awesome
Message 10 of 18
thank you brother. your answer absolutely solved my problem too.
Message 11 of 18
In Plant 3D the only way I can get it to work is to key in -group then name it then give it a description then it will finally create the group.
Pickstyle setting did nothing and yes my group was turned on.
Command: -GROUP
Command: Enter a group option
[?/Order/Add/Remove/Explode/REName/Selectable/Create] <Create>: C
Enter a group name or [?]: hose
Enter a group description: reel
Select objects: Specify opposite corner: 20 found
Message 12 of 18
lakopyan
Had the same issue and this solved it. Thanks!
Message 13 of 18
dburkeL5LDY
hi,
im having the same issue.
did you manage to sort it out??
Message 14 of 18
yasmine.medjahed
thank you, it works
Message 15 of 18
davidgoodpe
Type in CONFIG this opens the Configuration dialogue box. Pick the Selection tab. Under Selection Modes, check the Object Grouping box. Pick Apply.
Message 16 of 18
pendean
in reply to: davidgoodpe
Greetings.
Do you mean this? PICKSTYLE command, already discussed
Message 17 of 18
davidgoodpe
in reply to: pendean
This is for the Group command.
Message 18 of 18
pendean
@davidgoodpe indeed it is, the topic of this discussion is GROUP: are you unfamiliar with what PICKSTYLE variable affects by chance? From HELP
https://help.autodesk.com/view/ACD/2023/ENU/?guid=GUID-0F1D2321-E474-48AA-9179-98F17CCCA239
Forma Design Contest
Technology Administrators
