Howard Walker
Solved by pendean. Go to Solution.
As you can see typing in GATTE calls up the -ATTEDIT command,
I don't need to use BATTMAN. I'm trying to change the text value. I'm only using DATE as an example
eg
I have 10 pages of drawings and each one has a different TITLETOP text. HOWEVER I want them all to be the same TITLETOP TEXT.
According to the link I should be able to do that.
Howard Walker
The dialogue is a little misleading, when the prompt asks for the value specification it is expecting the current value of an attribute to find, in your case that is "date" the current value, then it can find the appropriate attribute, and it will ask again for the string to be changed, followed by new string.
so the responses should be
N N Block Name or* (limits to named block or all) Tag or* (limits to one tag value or all) Current String or* (limits to one attribute value or all) Current String (finds specific value to change from the blocks selected above) New String
Still doesn't work properly. I want to be able to change attributes on ALL PAGES. It's only selecting the attributes on ONE PAGE. Try the attached drawing and you'll see what I mean.
Howard Walker
In LT at least that command only works on the current screen (hence the prompt "visible on screen"), and not between layouts, you can run it as a macro, but again the LT limitation shows up and you have to know the layout names, though I do have a vague recollection of being able to swap layouts by reference number I can't remember how at the moment. Though looking at the help file CLAYOUT might do it, but I can't test it as it's not available in 2012
^C^C^Cctab;"Layout1";attedit;n;n;*;*;*;date;MAR 17;ctab;"Layout2";attedit;n;n;*;*;*;date;MAR 17;ctab;
Won't work for me. Layout names are always different.
Howard Walker
Nope that won't work either. I suppose I'll just have to put up with doing it the long way.
The below is what I got with CLAYOUT
Command: CLAYOUT Enter new value for CLAYOUT <"A2_4250-6*D55B5">: *Cancel* Command: *Cancel* Command: *Cancel* Command: <Switching to: A2_4250-8> Regenerating layout. Regenerating model. Command: CLAYOUT Enter new value for CLAYOUT <"A2_4250-8*D6721">:
Howard Walker
Head Office designed it and until head office say different that's what I have to use
Howard Walker
1. Which part of the GATTE function are you looking for (what in detail you are missing)?
2. Is it enough if the solution has to be controlled by hand or are you looking for automation?
The easiest way would be if you describe the current task.
What can you currently NOT do without GATTE?
If you like to change the attribute value of Attribut"X" in all blockreferences of Block"Y",
then select all and change the value by using the properties palette.
How to select all unnested blockreferences in your file: Command: FILTER
Sebastian
[Having a 20 page design]
-"needing to update the designers name which is common to all drawings"
a) If all old names the same, or differently attribute-tags: Command: FIND
b) Select all Title-blocks (command: FILTER, Filter, [Apply], Object-Selection: ALL) and edit the na...
Sebastian
