Font and text issues with LT2025
trthompson423
trthompson423
Community Visitor
Community Visitor
I have recently updated to the 2025 LT version of CAD and have some issues with all of my old files. When I open a drawing, the text in both model space and on my layout pages, the text shows up all over the place. The Mtext boxes are all in the correct spots, and open when I double click, but the actaul text is all over and moves when I zoom. It also appears very sporadic in plot preview, but when I open the plotted pdf, all of the text is normal and as should be. This makes it impossible to edit my layout and spacing for my text and final design. Any help would be amazing. I am a regular CAD user and this has me stumped.....and stressed with deadlines approaching!
Thank you!
h_s_walker
Can you post a screen shot of both your drawing and the PDF
Howard Walker
Left Handed and Proud
pendean
Community Legend
Community Legend
I suspect you just need to turn off ANNOALLVISIBLE command like you did in your preview LT versions, see link below (some of us need to restart LT after changing that setting, so you probably need to do the same too)
https://help.autodesk.com/view/ACDLT/2025/ENU/?guid=GUID-D8E50F6F-FB71-4A20-A3B9-7701C0518B81#:~:tex....
vinodkl
Hello @trthompson423
This is a known issue in AutoCAD 2025. This issue has been fixed in the update 2025.1. Please update to fix this issue.
You can download the update from here: https://manage.autodesk.com/products/updates
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
