Pasting from Excel formatting
masumiNYMDW
Message 1 of 11
masumiNYMDW
Hi
When I copy and paste a value from Excel, the AutoCAD make keeps the font and make it bold.
So every time I paste them, I have to right-click > Paste Special > and Paste without Character Formatting.
Is there a command such as CTRL+V+something?? that I can use to automatically paste without Character Formatiing.
I want the pasted text to match the other thickness, not bold like in the picture.
Replies (10)
Message 2 of 11
pendean
Community Legend
Community Legend
No, there is no other built-in option to do what you want between the two programs to skip that right-click.
There are WindowsOS add-ins that remove formatting from the clipboard if you want to experiment there, or transition through a 3rd app (like Windows Notepad) to remove formatting first.
Sometimes it's just quicker to type those few digits or numbers while in AutoCAD/LT: another option.
Message 3 of 11
masumiNYMDW
Oh That's very sad. Hope this improve someday! 😄
Thank you for answering!
Message 4 of 11
masumiNYMDW
Oh That's very sad. Hope they will improve this someday! 😄
Message 5 of 11
h_s_walker
@masumiNYMDW What version of AutoCAD are you using?
If you set up a table style in AutoCAD with all the settings you want, you can use the PASTESPECMODE variable to paste the table into your drawing using the table style you set up. See the link and image below.
AutoCAD 2023 Help | PASTESPECMODE (System Variable) | Autodesk
Howard Walker
Left Handed and Proud
Message 6 of 11
masumiNYMDW
I think I set up table style and set the PASTESPECMODE at 1, but the pasted text in the mtext box retain the excel font and colours. I'm using AutoCAD LT 2025.
Any idea why it's not changing the text style??
Message 7 of 11
h_s_walker
Can you post a drawing with a blank table which has your settings
Howard Walker
Message 8 of 11
masumiNYMDW
Hi
I'm sending the drawing! 🙂
Message 9 of 11
h_s_walker
See the image at the bottom of this post.
What you have posted is multiline text. To paste from excel just right click, choose "Paste Special" and then choose "Paste Without Any Formatting"
You can see I have pasted the text normally into your multiline text before I did the above.
You will also see I inserted a table and pasted the same text into the table and it has "forgotten" the excel formatting.
Howard Walker
Message 10 of 11
paullimapa
OP:
"So every time I paste them, I have to right-click > Paste Special > and Paste without Character Formatting.
Is there a command such as CTRL+V+something??"
@masumiNYMDW another words the answer seems to be no.
Paul Li
IT Specialist
@The Office
