AutoCAD LT Forum
Flyout too long for screen
2 REPLIES 2
177 Views, 2 Replies
I have some custom flyouts that are too long for the screen. How do i make go to 2 columns or go horizontal instead of vertical?
2 REPLIES 2
I'm presuming you're using a version that has the CUI-based customization environment. When you have the Custom Toolbar active in the editor, look in the Properties -portion of the editor.(On the right) The Rows-value will give you an option to make the toolbar to split into as many rows as you want (or columns as the case may be) The Orientation in turn lets you change the Vertcal/Horizontal aspect.
HTH
Petri
you don't: create another second flyout or as suggested change it's
orientation, or increase your windows display settings for more screen
real-estate.
Dean Saadallah
http://LTisACAD.blogspot.com
Add-on products for LT
http://www.pendean.com/lt
Forma Design Contest
Technology Administrators
