Flip Dimension text to Other Side
Message 1 of 26
I have a vertical dimension where I need the dimension text below the extension line and on the right side of the dimension line.  The attached screen shot shows the way Autocad places it.  How do I move it to the other side of the dimension line and still keep the dimension below the extension line and keep the 90° leader?
Replies (25)
Message 21 of 26
hallsup
Community Visitor
Community Visitor
Thanks for posting your solution/ quick fix; never knew you could hover over the grips like that for dimensions! very helpful.
Message 22 of 26
kimK7B54
@Anonymous wrote:
I've FINALLY found a solution. In the properties of the selected dimension scroll down to the "Fit" section. For "Text Movement" change the value to "Move text, add leader". Dimension.PNG
This would be called a "Workaround".  Not a fix.
Message 23 of 26
pendean
Community Legend
Community Legend
It is only a workaround if you decide to never make that setting in your DIMSTYLE in the first place, otherwise it is literally a user option you have to opt into, aka a fix  😉
Now you know: hope that helps.
Message 24 of 26
kimK7B54
I've been using Autocad for 30 years.  I'm very well aware of these settings.  It is a work-around because you have to deal with unwanted behavior when dragging dimensions around your drawing to optimize space and appearance.  A "Fix" would be a way to flip the dimension to the other side without using unfavorable settings.
Message 25 of 26
pendean
Community Legend
Community Legend
@ kimK7B54 Good to know. You may also know that what AutoCAD can do and what it be changed to do (aka what we might wish it/want it to do) is all we write about in these forums: to ask for a change to the core program behavior, it is best to do so where Autodesk looks for feedback from us end users, over here https://www.autodesk.com/company/contact-us/product-feedback
FYI: Pretty much everyone here replying to posts have 30-ish years in the program, we are all end users just like you, guiding each other to where to get the most out of the program.
Message 26 of 26
JBerns
Thanks for the feedback and glad it was helpful. Feel free to give the original post a "Like" vote.
CAD Administrator
Using AutoCAD & Inventor 2025
Autodesk Certified Instructor
Autodesk Inventor 2020 Certified Professional
Autodesk AutoCAD 2017 Certified Professional
