Autocad LT 2014 file crash
I have autocad Architect LT 2014 in my Mac computer. After 3 days of work the drawings file I was working on closed unexpectedly, and now I can only see the changes I made during the 3 days in paper space, but NOT in model space. Is there a way to retrieve the work and can you suggest a way to clean up the file if it is corrupted to avoid this from happening again. I tried several troubleshooting suggestions found on the website, but nothing worked.
Thank you,
Sergio
pendean
Community Legend
Community Legend
See your other post
Emmsleys
Following up on your thread, were you able to find a solution or a workaround?
Did any of the posts in the thread help with the issue?
Please use the Accept as Solution for those post’s that helped. It may benefit other users who might have a similar question or issue.
Or post with any new updates if you need continued help on your thread.
Thanks for your time.
Sarah Emmsley
Technical Support Specialist
Emmsleys
@Anonymous,
I'm following up on my previous post if you have any questions or found a workaround post back with any new updates.
If you still need help or have questions I'll be more than happy to help.
Thanks.
Please select Accept as Solution if my post or any other post in this thread resolves your issue, or reply with additional information if the problem persists.
Sarah Emmsley
