I want to find the center of mass of an irregularly shaped 2D object. I enter massprop. The command line reads "MASSPROP Select objects". I place the cursor in the center of the object and left click. The command line shows "Select object: 1 found". There is nothing else displayed. If I press enter, the command line reads "No solids or regions selected".
If I enter "Region" the command line reads "Region Select objects". The message then reads "Select objects: 1 found. " When I hit enter, I get the message "1 closed, degererate or unsupported object rejected, ) loops extracted, 0 regions created."
I believe that the object is properly bounded because I am able to hatch it.
How can I find the Center of Mass of this object?
Solved by pendean. Go to Solution.
