Solved by john.vellek. Go to Solution.
HI @Anonymous,
I saw this older post and I was curious whether you had ever found a solution. Since I don't have your script it will be difficult for me to test. If you are still having this issue, please attach a sample block(s) and your script so I can try to troubleshoot this for you.
One thought is to replace the % in the attribute name with a different character such as an underscore and see if the same problem exists.
Please hit the Accept as Solution button if my post fully solves your issue or answers your question.
Hi John,
Actually, the fix we settled on was to open the file in Notepad++ (we save in DXF format), search for all instances of "%%%" and replace it with "%".
It works for now. I'm trying to get away from these templates lately anyways.
