AutoCAD LT Forum
File save jumps to sheet set
4 REPLIES 4
Akunkinga
270 Views, 4 Replies
Has anyone else a problem autocad lt 2023 windows 11
when I go to save a drawing by clicking on File ( then Save) the sheet set manager wizard opens before I can click on the save
Tags (1)
4 REPLIES 4
paullimapa
in reply to: Akunkinga
questions:
what if you try clicking on another menu like Edit or View?
what if you just type at the command line: .QSAVE
Paul Li
IT Specialist
@The Office
pendean
Have you installed the 2023.1.2 Update yet? ABOUT command will confirm what you have installed. If not, get it from your Autodesk Account Page here https://manage.autodesk.com/cep/#products-services/updates
Restart your PC afterwards.
See if that helps. No issues for us in our offices.
jami.gann
Any solution? I am having the same issue.
pendean
in reply to: jami.gann
Restart your PC.
Install all updates too: if you are not sure you have those (it requires a deliberate download/install), start ABOUT command and share a screenshot of that pop-up here.
Forma Design Contest
Technology Administrators
