Hi to all
I'm using AutoCAD 2019 and I'm taring to make dynamic block to elbow , I need some help to how can adjust the arcs with end of lines. , how can controlling the start of arcs points . I attached my block to show and tell me where my fault. Thank you
If you are making this in full AutoCAD? why post the question in the LT forum, LT cannot create constraints, the problem is the sizes you are using in the block table, the centre of the arc remains constant and everything else is based on that point (or at least it should be) you just need to go through and find which measurements are off in the table by working backwards from that arc centre point.
please ... to get a real help , post your question here . >> Dynamic Blocks Forum <<
All the best...
Imad Habash
