I am getting Fatal Error issue in my AutoCAD LT 2018 from last few days.
Event Viewer log -
Faulting application name: acadlt.exe, version: 28.0.49.0, time stamp: 0x58944c59
Faulting module name: ucrtbase.dll, version: 10.0.10586.0, time stamp: 0x5632d193
Exception code: 0xc0000409
Fault offset: 0x00000000000698fe
Faulting process id: 0x1970
Faulting application start time: 0x01d2ddda97372159
Faulting application path: C:\Program Files\Autodesk\AutoCAD LT 2018\acadlt.exe
Faulting module path: C:\Windows\SYSTEM32\ucrtbase.dll
Report Id: bbf667b5-7262-425a-8f7a-35a47a014c44
Faulting package full name:
Faulting package-relative application ID:
Kindly give solution asap.
This error can occur for a number of reasons. See below link for suggestions on how to rectify.
A few tests to run so that we can narrow down where the issue might be:
A few questions;
Thanks for providing that information.
Are you running into this issue with other releases? Have you applied all updates?
If possible could you provide the answers to the rest of my questions? It helps give me and others a better idea of what suggestions to offer up next.
Thanks.
I'm following up on my previous post. If you have any questions about my post let me know.
If you still need suggestions or have questions I'll be more than happy to help.
Thanks.
Please select Accept as Solution if my post or any other post in this thread resolves your issue, or reply with additional information if the problem persists.
To add for any other user who might have a similar issue.
You can also find the information below at this article link:
There are several ways to troubleshoot the problem:
Update AutoCAD.
Updates for latest releases are acquired via the Autodesk Desktop App. Right-click its icon down on the status bar next to the time and pick "Check now." You may also download updates through your Autodesk Account (see How to Access Product Updates in Autodesk Accounts). For older products, see Autodesk Downloads.
Reset AutoCAD to defaults.
See: How to reset AutoCAD to defaults
Turn off Hardware Acceleration.
See: Starting AutoCAD-based products without hardware video acceleration
Update your graphics driver.
Install the latest graphics driver from your video card manufacturer or use an AutoCAD-certified driver.
See: How to update your system to the latest certified video driver
Try logging in under a new Administrator Windows Account.
If you create a new account and can successfully open the drawing, you can either use that account or rebuild the user profile in Windows.
See: How to create a new local administrator Windows user account
Uninstall and reinstall the .NET Framework.
See: How to remove and reinstall the Microsoft .NET Framework
Uninstall and reinstall Visual C++.
See: How to remove and reinstall Microsoft Visual C++ Runtime Libraries
Clear the digital signature icons and then uninstall and reinstall the application.
See: FATAL ERROR: Unhandled Access Violation Reading 0x0000 Exception at 4048b9h
