FATAL ERROR
FATAL ERROR
vaibhav.deshmukh
Observer Observer
Message 1 of 9
FATAL ERROR
vaibhav.deshmukh
Observer
Observer
I am getting Fatal Error issue in my AutoCAD LT 2018 from last few days.
Event Viewer log -
Faulting application name: acadlt.exe, version: 28.0.49.0, time stamp: 0x58944c59
Faulting module name: ucrtbase.dll, version: 10.0.10586.0, time stamp: 0x5632d193
Exception code: 0xc0000409
Fault offset: 0x00000000000698fe
Faulting process id: 0x1970
Faulting application start time: 0x01d2ddda97372159
Faulting application path: C:\Program Files\Autodesk\AutoCAD LT 2018\acadlt.exe
Faulting module path: C:\Windows\SYSTEM32\ucrtbase.dll
Report Id: bbf667b5-7262-425a-8f7a-35a47a014c44
Faulting package full name:
Faulting package-relative application ID:
Kindly give solution asap.
Replies (8)
Message 2 of 9
múinteoir
This error can occur for a number of reasons. See below link for suggestions on how to rectify.
https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Error-...
Múinteoir
The face of the BIM game | Former Autodesk Expert Elite | YouTuber | Lego Builder | Monaghan Man | Some Can, Some Cant
Message 3 of 9
rkmcswain
Was it working okay before some point in time? If so, what changed just before it started doing this?
A different data set?
New hardware installed?
Windows updates?
New drivers?
For starters....
Make sure you have a supported video card, and a recommended/certified driver for it. (See http://usa.autodesk.com/adsk/servlet/syscert?id=18844534&siteID=123112 )
Make sure your %temp% folder is not bloated - clean it out.
Message 4 of 9
Emmsleys
Hi @vaibhav.deshmukh
A few tests to run so that we can narrow down where the issue might be:
  • Test AutoCAD LT in a new user login with full admin rights. This way we can test AutoCAD LT in a default settings environment.
  • Is this happening with all of your files? Test a brand new file and capture of a screengrab should a fatal error message show up.
A few questions;
  • Do you have other versions of AutoCAD LT on your system? 2017,2016,2015?
  • What OS are you running?
Sarah Emmsley
Technical Support Specialist
Message 5 of 9
vaibhav.deshmukh
Observer
Observer
1. I have other version of Autocad also like 2011, 2013, 2015
2. I have all the system running Windows 7 Pro and in one system Win 10 Pro
Message 6 of 9
pendean
Community Legend
Community Legend
Perform the test and answer the other questions noted as well:
Message 7 of 9
Emmsleys
Thanks for providing that information.
Are you running into this issue with other releases? Have you applied all updates?
If possible could you provide the answers to the rest of my questions? It helps give me and others a better idea of what suggestions to offer up next.
Thanks.
Sarah Emmsley
Message 8 of 9
Emmsleys
I'm following up on my previous post. If you have any questions about my post let me know.
If you still need suggestions or have questions I'll be more than happy to help.
Thanks.
Please select Accept as Solution if my post or any other post in this thread resolves your issue, or reply with additional information if the problem persists.
Sarah Emmsley
Message 9 of 9
Emmsleys
To add for any other user who might have a similar issue.
You can also find the information below at this article link
There are several ways to troubleshoot the problem:
Sarah Emmsley
