Fatal Error
Fatal Error
albertanwk
Observer Observer
Fatal Error
albertanwk
Observer
Observer
Hello Sir,
I have problem when try to open 2 CAD dwg. The fatal error keep pop out. Hope to hear your reply soon.
Thanks & Regards,
Albert
paullimapa
if this error only occurs on one particular drawing then it's possible that drawing file is corrupted.
you may try using the RECOVER command to open that dwg file.
Paul Li
IT Specialist
@The Office
albertanwk
Observer
Observer
Hi, it didn't seems to be the way. I have tried open other drawings, it also showed the same thing. When I open one CAD dwg, it seems fine, but when I try to open another drawing, the fatal error came out.
paullimapa
Did this problem just suddenly occur?
Has there been any changes to your computer?
What version of Windows are you running?
Run AutoCAD with a new dwg opened only and enter About command. Do a screen capture and post that here so we know what version of LT you’re running
Paul Li
IT Specialist
@The Office
albertanwk
Observer
Observer
Actually I just installed in my computer and it occurs this problem. My current window is Window 11 Pro and the Autocad LT version I using is 2016.
paullimapa
The problem is 2016  is not compatible with Windows 11
Paul Li
IT Specialist
@The Office
pendean
Community Legend
Community Legend
@albertanwk LT2016 is not supported in Windows 11, but then again you forgot to install the most important SP1 update for LT2016 that made it work well in Window10 (which might help it work in Win11) https://download.autodesk.com/us/support/files/autocad_2016_service_pack_1/AutoCAD_2016_and_AutoCAD_...
You might find it in this search page if you for some reason never got it and stored it safely for you back in the day https://www.google.com/search?q=lt2016+sp1+download
Best Wishes.
