So about my english, i m dutch normally. So first i gonna explain the situation. I Draw structures in Concrete on Autocad LT 2013. This is always in a template dwg with our standard blocks or settings. When i m finished, element is ready, custom properties is adjusted.
Then the second step is drawing the reinforcement by my colleague in AUTOCAD STRUCTURE DESIGN 2013. But every time she opens a drawing she gets a fatal error. (the one showed in the pdf). we also did some experiments like purging audit. copying everything to a brand new dwg. remaking the blocks. so you can say i lost quite some time on it. but nothing works and it seem to get worses the more advanced our drawings becomes (blocks etc.). it has also something to do with luck. like 1 of the 4 times we can open the same drawing. i also noticed if we zoom out or in a clean area ( with no lines or other objects) we get more luck that she can open that drawing. the reinforcement that she draws (in ASD) is showed as proxy objects in LT.
Anyone some opinions or solutions cause it really getting on my nerve and i losings lots of times 'cause it.
greets Dieter
Solved by pendean. Go to Solution.
Welcome to the Autodesk Forums!
Is Structure in the Revit Family?
If so you may want to review this:
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
Have you tried opening a file using Recover with the ASD Seat?
See if that returns any errors there?
The Proxy warnings make sense since the vertical (ASD) saved file is being opened by the generic (LT) program.
she just did a recovery with ASD. en it tells audit didn't found any error. Well that's the problem, we don't know where the problem is, it can be with ASD or with LT. Autocad Architecture and AutoCAD has no errors with the drawing.
I am using Autocad 2012 LT and 2013 LT, when i am copy paste in diffrent drawing suddenly show fatal error or low memory message , i have core 2 duo processor and 2 GB ram, i have reinstalled OS and autocad LT version but same as problem , do not resolve problem till date. please give me a guidance and how to resolve it.
